you should have shock and spring together held by a top plate held down by a nut tightened, then the bearing goes on, top mount over the top of that, then place in turret, tighten in bay with last nut, this should allow for the mount not to move, i drop the car down and re tighten the top nut up as the weight of the car helps, if you have movement still your mounts are worn
