Author Topic: mk3 recaro interior into mk2  (Read 2227 times)
Offline rossbarry1
« on: 14 May 2011, 19:41 »
does anyone know what is involved in fitting this into my mk2 gti. I was hoping to get the door cards to match but not sure if they will fit. cheers
Re: mk3 recaro interior into mk2
« Reply #1 on: 14 May 2011, 23:58 »
Seats will need mods and welding, door cards will not fit.
Offline Benrevs
« Reply #2 on: 16 May 2011, 12:11 »
Door cards will not fit.  The front seats are easy, you need to separate the base from the backs, take the foam and fabric off the bottom and swap onto the mk2 frame, then bolt back together... Easy. The rears you will need to weld the brackets from a mk3 shell as the seats split 60/40.
