Author Topic: ABF conversion. ISV and idle problems  (Read 4288 times)
Offline Mr Blue
« on: 14 May 2011, 15:13 »
Hello mk3'ers
Did a search but no clear answer.
I have a mk1 with an ABF conversion running ABF management.
It doesnt idle. Engine does run but just the idle is a problem. (cuts out)
The ISV does not buzz. I have no 12v at the ISV plug.
What should I check now?
thanks :smiley:
Offline Mr Blue
Re: ABF conversion. ISV and idle problems
« Reply #1 on: 15 May 2011, 11:39 »
checked the ISV, check the throttle switch for ohms, checked the throttle position sensor,
checked all earths and wiring with no visible faults.
Still getting 0.4v at the ISV plug which i have been told it should be about 5-7v.
Could this be the ECU relay? number 30.
The relay 167 is fine and has been changed.
Offline Len
« Reply #2 on: 15 May 2011, 12:36 »
Doubt very much its the ECU relay.
Have you checked all the vacuum hoses?
And engine breathers?
www.sas.org.uk
www.the-ace.org.uk
Offline justalex81
« Reply #3 on: 15 May 2011, 12:50 »
turn key to first position and isv should hum/buzz. If it isn't then that's the first thing to look at
Offline MK3GTI_16Valve
« Reply #4 on: 15 May 2011, 18:08 »
not all buzz from what i read before.....
Offline Mr Blue
« Reply #5 on: 15 May 2011, 23:14 »
I have checked all vacume hoses and everything is connected.
The breather pipe that comes off the square box is not connected to anything. Doubt this is the problem.
Replaced ISV for a new working one.
I get 0.4 v at the ISV plug. The idle problem is due to the isv not buzzing. :sad:
I also have no readings from the coolant temp sensor (two green wires)
Is their a relay for the ISV?
« Last Edit: 15 May 2011, 23:17 by Mr Blue »
Offline Mr Blue
« Reply #6 on: 18 May 2011, 00:00 »
Sorted now. Thanks all the input.
Turns out the White ISV wire goes to the ECU pin 27
Black ISV wire has now been fused to 12v ignition live.
All idle problems sorted and isv working  :smiley:
Offline Len
« Reply #7 on: 18 May 2011, 09:04 »
Mine does NOT buzz! Had my car for 7 years and it idles fine! :smug:
www.sas.org.uk
www.the-ace.org.uk
Offline justalex81
« Reply #8 on: 18 May 2011, 09:21 »
like i said before len its probably stuck open at the right position  :laugh: :laugh: :laugh:
Offline Len
« Reply #9 on: 18 May 2011, 13:33 »
I wouldnt want it to buzz now!
And anyway I guess I wont be having one when the ITB's get fitted! :smug:
www.sas.org.uk
www.the-ace.org.uk
