Author Topic: HELP  (Read 1517 times)
Offline Trispage
HELP
« on: 13 May 2011, 17:56 »
My agu 1.8gti turbo was working fine. Took the stereo out this afternoon to tidy up some wiring, refitted the stereo all good. Tonight I go to nip to the shops and the car is dead. All ignition lights up as normal. Horn wipers lights etc all work. Turn the key to start and all I get is a faint hum. Almost
 as if the immobiliser is still on. Please help me I need my car for work. I have no vagcom so can't get any codes
Offline andc1
Re: HELP
« Reply #1 on: 13 May 2011, 18:13 »
try unplugging battery for a half hour and then try, or check the wiring behind the head unit, your clocks are part of the immo so check behind there
Offline richw911
Re: HELP
« Reply #2 on: 13 May 2011, 19:03 »
Dead starter motor  :smiley:
Offline Trispage
Re: HELP
« Reply #3 on: 13 May 2011, 21:35 »
Update. Left the car for three hours as I had to take the kids to hockey. Came home and thought I best put the car back on the drive for the night. Got in, turned the key and it fired straight up. Now I'm really confused. Anyone got any theories
Offline daz veedub
  • Operation 1.8t bolf
Re: HELP
« Reply #4 on: 13 May 2011, 21:49 »
mk4 gremlins   :rolleyes:
Offline new to vw
Re: HELP
« Reply #5 on: 13 May 2011, 23:31 »
The electrics on AGU are powered by VOODOO, where as on the AUM its WITCHCRAFT.... :grin: :grin:
Seriously though, if you have had the battery disconected for that length of time all of the residual charge will have left the systems...Its like a cold start for everything and resets itself... :grin: :grin:
5 door 1.8t AUM
Offline Trispage
Re: HELP
« Reply #6 on: 13 May 2011, 23:33 »
That's the scarey thing. I hadn't disconnected the battery
Re: HELP
« Reply #7 on: 14 May 2011, 00:19 »
See if it happens again.  :undecided:
Offline Trispage
Re: HELP
« Reply #8 on: 14 May 2011, 10:51 »
Well, went out to the car this morning and once again it's not starting. Beginning to worry me now
Offline Trispage
Re: HELP
« Reply #9 on: 14 May 2011, 12:50 »
FIXED IT. After stripping out the dash to check the Immobiliser wiring and getting nowhere I decided to check else where. Turns out the starter motor solenoid wire had snapped and was intermittently touching. Soldered it back together but want to know if the is a part number for a new one. Cheers people
