Author Topic: petrol tank retaining ring how to remove  (Read 758 times)
Offline lockey
« on: 12 May 2011, 23:37 »
Doin a tdi into gti conversion was hopin to just swap over tank units rather than tank but when i tried to put the tdi unit into the gti tank it wont sit properly because the black retainer ring that held the fuel pump in isnt letting it sit down. Can this be removed or do i have to swap tanks
Offline dom
  • Back in a Mk4
Re: petrol tank retaining ring how to remove
« Reply #1 on: 12 May 2011, 23:39 »
At a guess i'd say your probably better swapping the tanks over :undecided:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 12 May 2011, 23:42 »
If I remember rightly the tank is larger on the derv.
Offline lockey
« Reply #3 on: 12 May 2011, 23:47 »
 :sick: is there much to swappin tanks or just undo the two straps and diesel and gti are same depth anyway
« Reply #4 on: 12 May 2011, 23:48 »
Should be easy to swap over, straps should be the same unless the tank is larger.
