Author Topic: Actuator..???  (Read 933 times)
Offline D4VEY01
  • 1999 GTI 1.8T AGU BLACK
Actuator..???
« on: 12 May 2011, 22:20 »
How do u know if its broke,or weak and is there a simple test to see if its operating correctly..?
Thanks
1999 : GTI : 1.8T : AGU : SPEC 1 R-TECH REMAP : BOSCH SUPER 4 : FORGE TIP : SILICONE TURBO HOSE KIT : 18" RS4 ALLOYS : -30MM ADJ SPAX SHOCKS/SPRINGS : FORGE 007P D/V (YELLOW) : MILLTEK CAT BACK RES 4MOTION : POWERFLEX DOG BONE BUSHES : PIPERCROSS FILTER : FORGE ACTUATOR (YELLOW) :
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Actuator..???
« Reply #1 on: 12 May 2011, 22:29 »
Thanks
Data logging blocks 25 with VCDS and graph them, or mini vac test to see where it starts to open and when full open and at what psi, or use fish scales and pull on the arm, or just pull it with your hand and compare with a new one.
Nick
 01455 617233
Offline D4VEY01
Re: Actuator..???
« Reply #2 on: 12 May 2011, 22:35 »
Nice 1 Nick.
Offline gtti_234
Re: Actuator..???
« Reply #3 on: 13 May 2011, 00:26 »
Get a forge actuator!!!! far better!! :smiley:
spax coil overs, 18ins rs8 alloys,007 forge dv,n75j,piper cross induction, r-tech stage 2 remap, custom chromes decat exhaust + 3" down pipe, forge actuator g60 flywheel vr6 clutch, forge tip, deleted pvc catch can install,
