Author Topic: turbocharger  (Read 967 times)
Offline matping
  • MK1 20vT MK5 GTI T
turbocharger
« on: 12 May 2011, 21:21 »
does anyone know if a ko3s turbo from a octavia vrs will fit the agu ?
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
Re: turbocharger
« Reply #1 on: 12 May 2011, 21:31 »
Yea it wil mate :smiley:
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline matping
Re: turbocharger
« Reply #2 on: 12 May 2011, 21:33 »
thankyou !  :smiley:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: turbocharger
« Reply #3 on: 12 May 2011, 21:34 »
Yes,
you just need the forge tip and the top turbo outlet pipes from the k03s is its the later silenced version.
If you get stuck you can drop us a line on 01455617233 an we can offer advise
Nick
 01455 617233
Offline thatwillis
Re: turbocharger
« Reply #4 on: 12 May 2011, 22:01 »
I've got myself a k03s to install on my agi. I'm currently looking for a second hand forge TIP before fitting but i wasn't aware of the top turbo outlet pipes needed...
Offline RTechUK
Re: turbocharger
« Reply #5 on: 12 May 2011, 23:31 »
Only on the silenced K03s from a late 2002/03 1.8t will you need the 90 bend top hose.  The unsilenced hose is too loose and will never tighten up correct without leaking or even popping off.
 01455 617233
