Author Topic: mk1 golf with mk2 gearbox. Speedo issues  (Read 3131 times)
Offline Mr Blue
« on: 12 May 2011, 20:51 »
Hello all.
I'm new to mk1's so sorry if its been asked before (search wont work for me)
I have a mk1 golf with an ABF engine, abf management and mk2 gti gearbox. Now I want the speedo to work but not sure how I can go about this? right size cog, cable etc....
Im running 15'' wheels with a horrible 50 profile tyre!
Any help would be much appreciated.
thanks  :smiley:
« Last Edit: 12 May 2011, 21:34 by Mr Blue »
Offline SoundillusioN
Re: mk1 golf with mk2 gearbox. Speedo issues
« Reply #1 on: 13 May 2011, 16:09 »
Firstly... its amazing what happens after just a couple of weeks absence! when did you get a mk1!!... secondly what's the issues, does the speedo not work at all or is it reading incorrectly?
Offline Mr Blue
« Reply #2 on: 13 May 2011, 20:11 »
Hello mate  :grin:
Picked up an ABF engine mk1 yesterday localy. Its got a mk2 gti box (need to check which one)
Speedo cable is bolted in but no movement in the speed needle. Just needed to know what gearbox cog I should use if its a KR box or normal 8v box. :smiley:
Its running 15's with 50 profile tyres if that helps.
BTW the mk1 is black non sunroof, fully poly bushed, mk2 gti 16v front brakes, mk2 gti rear disk conversion, mk4 rear calipers, 3 piece split rims, stainless exhaust and the best bit...running an ABF with full ABF management.  :cool:
« Reply #3 on: 14 May 2011, 00:17 »
I believe you need a mk1 gear.
You may find the gear has fallen off.
Offline Mr Blue
« Reply #4 on: 14 May 2011, 19:17 »
had a look at it. The cable has seized! Looks like a mk2 red cog but will find out.
Thanks for the tip. New cable needed :smiley:
