Author Topic: "linking Error"  (Read 2934 times)
Offline gumie30
"linking Error"
« on: 12 May 2011, 18:37 »
Yet another day, Another problem
Everytime i try to scan the car this message keeps popping up :sad:
is there any way of getting around the problem?  its sending me bonkers :laugh:
99t 1.8t if that helps.
cheers gumie30.
Offline Adam
Re: "linking Error"
« Reply #1 on: 12 May 2011, 18:47 »
Is it a handheld scanner or VAG-Com/VCDS?
Also might be a silly question, but have you put your ignition on when you scan it?
Down Hill From Here.
Offline gumie30
Re: "linking Error"
« Reply #2 on: 12 May 2011, 18:50 »
its a scanner of fleabay the ones that everyones been getting
yeah have tried it with ignition on/off and still nowt...
Offline Adam
Re: "linking Error"
« Reply #3 on: 12 May 2011, 18:53 »
I would try another scanner or send that on back. That one might be faulty :huh:
Offline gumie30
Re: "linking Error"
« Reply #4 on: 12 May 2011, 19:00 »
But it works on the r lasses car and mates seat cupra..but not mine
Its driving me mad mate...
Offline andc1
Re: "linking Error"
« Reply #5 on: 12 May 2011, 19:07 »
clean the connectors in the car
Offline stevelfc
Re: "linking Error"
« Reply #6 on: 12 May 2011, 19:59 »
my m8 brought one and starts connecting to the car then stops and says linking error but works on other cars so must be scanners are sh!te lol
Offline houston
Re: "linking Error"
« Reply #7 on: 12 May 2011, 20:18 »
Have you got an aftermarket stereo fitted? Check to see the harness hasnt been bodged
Offline gumie30
Re: "linking Error"
« Reply #8 on: 12 May 2011, 20:25 »
The stereo is an aftermarket one, i had no power too the obd port before, so ive had the stereo fitted properly...and now i have got power but its not reading the ecu... :angry:
Offline houston
Re: "linking Error"
« Reply #9 on: 13 May 2011, 10:48 »
then maybe the k line wire has been cut if the harness has been hacked
