Author Topic: Is it possible to remove the exterior door trim plastics?  (Read 2304 times)
Offline chiefwhosm
Hi,
    I was wondering if it's possible to remove the plastic trim thats on the midpoint of each door exterior to check there's nothing nasty lurking behind it (there's definately moss growing around it). If so does it bolt on or......
Thanks,
           Chief :)
Offline mk1.8t
just give it a gentle pull there just held on with clips
Offline VR6_Wherry
Don't be suprised of the clips snap though, it's not uncommon all mine did! :grin:
You will need new clips when you refit them.
Don't bother with the ebay clips get genuine ones.
Offline chiefwhosm
Thanks for the replies.
On the first door I tried only the very last clip broke. :grin:
Chief :)
« Last Edit: 12 May 2011, 22:34 by chiefwhosm »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Having recently switched from GTI to CL door strips i can confirm that you will almost certainly require new clips, it's the shallower white end ones that always snap. the longer central ones ive never had any issues with what so ever.
As for what you've said about buying genuine ones....the clips i purchased from B&B Components were absolutely fine.
http://cgi.ebay.co.uk/VW-GOLF-MK3-GTI-TRIM-CLIPS-C18-/220536441271?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3358ff09b7
« Last Edit: 13 May 2011, 01:08 by thai-wronghorse »
