Author Topic: Gti master cylinder removal question...  (Read 801 times)
Offline tommy Dee
« on: 12 May 2011, 15:20 »
I have been through the search bar and maintenance section but can't find an answer.....
I've undone everything, but am stuck at getting the clip outta the brake pedal.... Anyone got any tips??
Thanks guys :)
Offline dashey
Re: Gti master cylinder removal question...
« Reply #1 on: 12 May 2011, 16:20 »
The clip on the brake pedal is a proper c*nt but once you get hang of it its alright basiccly get to little flat head screw drivers and on ethier side of the pedal you will see 2 white dots basiccly one above the other and it on ethier side push the top one in on ethier side and push it forward if you can do the same with the 2 bottom ones and its out
Offline tommy Dee
« Reply #2 on: 12 May 2011, 20:01 »
Thank you very much mate!! I'll get back n attack it tomorrow :)
Offline tweed
« Reply #3 on: 12 May 2011, 20:33 »
I changed mine on my 16v but don't remember doing that  :huh:
Offline lockey
« Reply #4 on: 12 May 2011, 23:50 »
Some a the pedals have the four dots like said above if ur lucky you will have the one with two tabs that you can just pop out was told by vw mechanic common thing to break the clips as there tool for the job isnt any good think there a cheap part if worst comes to worst
Offline Dan_GTi8v
« Reply #5 on: 12 May 2011, 23:59 »
They cost about a fiver from vw, I replaced mine not long ago after snapping it trying to get it out. Fannied about for a few hours trying to to break it but in the end just janked the servo out and got a new clip
