Author Topic: Golf gti 2.0l 16 vs clio sport superchargered ecu remapp 200 bhp  (Read 4896 times)
Offline golf newbie
Nitro for the win.. :rolleyes:
Offline mani12354
:) isit a long process to fit a turbo ur self???  :rolleyes:
Offline Khare
  • The bear that khares
Research it fella. This is covered a few times a week so there's plenty of info threads kicking about. Don't expect to do a turbo/supercharge conversion for anything under £1500 though, even if your welding and fabricating skills are amazing.
Offline trog_nfs
Nah, all you do is slap on a Trust T88 turbo, and bobs your uncle 800hp on standard internals  :grin:
Here's the linky just in case you missed it http://www.golfgtiforum.co.uk/index.php?topic=192294.0 :)
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
fitting an eaton m45 to my mk1, from an slk230
picked up for a bargainous £50 on eaby ;)
M45 is only really good for up to a 1.6, will do very little on a 2.0
Wrong, the M45 was desgined for 2.0 to 3.0l Mercedes, the Cooper S varient runs lower % overdrive plus its a very good flowing head. If you know what you're doing the power is there to be made4
« Last Edit: 13 May 2011, 09:58 by MotorPsycho »
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Offline mani12354
=D can u do a twin turbo conversion on mk3 2.0 16v??
Nope not really, 1 would be enough.
Offline mani12354
 :shocked: i want 2  :grin:
What would be the point, you could only use 2 small turbos and a bigger turbo would give you more.
Plus you will struggle with room and heat issues etc.
« Last Edit: 13 May 2011, 10:57 by Wayne »
Offline trog_nfs
Sell your mk3, buy an R32, then you can go bug the mk4 section on how to twin-turbo that, as that can actually done.
