Author Topic: COOLENT LIGHT KEEPS FLASHING CONSTANTLY!  (Read 1482 times)
Offline mani12354
« on: 12 May 2011, 09:05 »
Anyone got any ideas what it could be water is topped up?
Offline golf newbie
Re: COOLENT LIGHT KEEPS FLASHING CONSTANTLY!
« Reply #1 on: 12 May 2011, 09:11 »
Have you tryed unplugging the sensor at the expansion bottle..
Offline mani12354
« Reply #2 on: 12 May 2011, 09:27 »
umm nope? :embarassed:
Offline robz
« Reply #3 on: 12 May 2011, 09:52 »
Try unplugging the sensor and see if it still flashes!
Maybe a knackered sensor, be careful though as it may be on for a reason ;)
Offline mani12354
« Reply #4 on: 12 May 2011, 09:56 »
it came up when i reattached  battery cable  :shocked:
Offline golf newbie
« Reply #5 on: 12 May 2011, 10:30 »
Ok. did you take off the sensor and not the battery cable.?
Check your earth straps give them a good clean.
If its not overheating i would say the only thing it could be is a faulty dash..
Offline mani12354
« Reply #6 on: 12 May 2011, 10:32 »
thing is, it was working before the battery got dc then the when i reattached it, then it started flashing  :shocked: but i didnt touch nothing to do wid the sensor  :shocked:
Offline golf newbie
« Reply #7 on: 12 May 2011, 10:39 »
Maybe you dislodged a wire or something.
Offline mani12354
« Reply #8 on: 12 May 2011, 10:58 »
thing is all i touched was the inlet manifold cable thats all  :shocked:
Offline trog_nfs
« Reply #9 on: 12 May 2011, 12:39 »
Take the plug off the sensor, and check its making contact with the two metal contacts. They can get bent out of shape quite easily. Bit of screw driver action might sort it
