Author Topic: Grands storm grey VR6! oshhhhh!  (Read 95270 times)
Offline GrandMstRamRod
Re: Grands storm grey VR6! oshhhhh!
« Reply #200 on: 13 October 2011, 19:43 »
This isn't going anymore then?
no mate, due to the leaking sump and the broken abs pump, but engines coming out and smoothing the bay, is the plan, and few other bits and pieces
« Reply #201 on: 14 October 2011, 15:22 »
small update....
« Last Edit: 14 October 2011, 16:28 by GrandMstRamRod »
Offline VR6_Wherry
« Reply #202 on: 14 October 2011, 15:28 »
When you are doing a project thread, words do help too!  :grin: :grin: :grin:
« Reply #203 on: 14 October 2011, 15:34 »
but at least there is f**k loads of pictures, unlike shady ;)
and I'm keeping quiet as I'm not fully decided on how to tackle what i want to do :P
first of all is replacing the sump seal and the abs pump!!!!
« Last Edit: 14 October 2011, 15:39 by GrandMstRamRod »
« Reply #204 on: 17 October 2011, 15:28 »
started stripping things today, chains look perfect, inlet manifold needs bit of cleaning internally, but first plan is to fix the two oil leaks so removed the oil filter housing, and sump which was a pain in the arse
things for the shopping basket are
drive belt if thats what its called
new gasket for the inlet manifold
sump gasket
oil
oil filter
carb cleaner
thats everything needed for the fix before anything interesting goes down..
« Last Edit: 17 October 2011, 15:48 by GrandMstRamRod »
« Reply #205 on: 20 October 2011, 11:27 »
engine stand bought! now the fun begins!! pics to follow in next few days
Offline Shady Pioneer
  • graphic designer.
« Reply #206 on: 23 October 2011, 14:00 »
Two can play that game.
Offline lemski
  • 16v
« Reply #207 on: 26 October 2011, 21:17 »
well lyouve done some things. whens the lump coming out
