Author Topic: Grands storm grey VR6! oshhhhh!  (Read 95285 times)
Offline Neo Badness
  • Feet are for pedals
Re: Grands storm grey VR6! oshhhhh!
« Reply #190 on: 08 October 2011, 22:35 »
the way my insurance works is as long as its no modification that adds BHP there is no extra cost!
 :cool:
mine covers my mod's like for like with an agreed value  :tongue: :kiss:
Offline GrandMstRamRod
« Reply #191 on: 10 October 2011, 12:02 »
mot was today pass but few small problems popped up!
got the right back abs sensor replaced, due it showing up on bag com scan, as the last owner possible unplugged the abs light!!!!!
also found sump gasket is leaking a little bit due to be replaced next monday which is going to be a paint
thinking of going down the audi sump root and replace the pump for the 3.2 shorter version!
« Reply #192 on: 10 October 2011, 12:52 »
Is it really worth it, yours is not that low.  :undecided:
« Reply #193 on: 10 October 2011, 13:05 »
yh just priced up second hand sump so much cheaper, so thats getting done monday! + more new oil as its spunked out the load it had ;)
« Reply #194 on: 10 October 2011, 14:56 »
went back with the vag-com had the rear right one replaced didn't know about rear left but tried clearing the codes and they both kept coming back, thanks to someone disconnecting the abs light and airbag! i have not known about this issue for over 10 months
VAG-COM Version: Release 409.1-S
Control Module Part Number: 3A0 907 379 A
  Component and/or Version: ABS/EDS ITTAE 20 GI V00
           Software Coding: 03604
            Work Shop Code: WSC 00000
2 Faults Found:
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
        35-00 - -
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
        35-00 - -
Offline myvr6isarocket
« Reply #195 on: 11 October 2011, 06:33 »
new one on me also fella,  i didnt disconnect anything from anywhere mate.?
sorry to hear it
if it doesnt clear, give me a shout
« Reply #196 on: 11 October 2011, 09:38 »
sorry to hear it
no worries, gotta get new left side abs and new pump hopefully after that it shall all be sorted, also re-seal the sump first due to it been running without oil for not sure how long!!   :sad:
Offline Bellend
« Reply #197 on: 11 October 2011, 12:22 »
Shame you're so far away.
I've got spare pump and ECU here if it matches. I can't really sell them as the ABS light bulb was blown and the ABS didn't work and I never scanned it.
Could just have been a sensor so you'd be welcome to the other two bits just to try and yours if they worked.
Where all my moneys went.
« Reply #198 on: 13 October 2011, 17:30 »
Start of a few fixes and something big
Offline Jack3559
« Reply #199 on: 13 October 2011, 19:11 »
This isn't going anymore then?
