Author Topic: No spark ??  (Read 1964 times)
Offline aj_golf
No spark ??
« on: 11 May 2011, 21:58 »
So I've stripped my engine Down an put it back together! (also fitted electric windows) but now when I turn the ignition on I get a spark but when I try an turn it over I got no spark??? Also engine is not turning over as quick as it should same sign as a flat battery? Any ideas??
Offline Thom89
  • Looking for an "Icebreaker"
Re: No spark ??
« Reply #1 on: 11 May 2011, 22:04 »
Have you double checked that ALL the earths are cleaned and re attached...
Thom
Offline aj_golf
Re: No spark ??
« Reply #2 on: 11 May 2011, 22:11 »
Yeah, I had to! I didn't the first time an blew the ecu but that's sorted now.
Offline tomp
Re: No spark ??
« Reply #3 on: 11 May 2011, 22:16 »
What about the ignition amplifier?
I blew an ECU on a mk2 digifant a week or so ago, borrowed another ECU and took it with the bracket and ignition amplifier, had the same symptoms as you when I fitted it. Put the original amplifier back on with new ECU back on and fired first time....
Offline aj_golf
Re: No spark ??
« Reply #4 on: 11 May 2011, 22:43 »
Yeah I swapped it an put my original one back on but still nothing. But took the ecu off an put it on my dads Gti an it fired his up. So I am really puzzled "/
Offline tomp
Re: No spark ??
« Reply #5 on: 11 May 2011, 23:21 »
Can only suggest the obvious really, spark from coil, dizzy cap, leads, good earth, etc
When your ECU went did it completely flood your engine? I put a blow torch on the spark plugs to dry them out, and had an air line down the spark plug holes to dry everything out...
Offline aj_golf
Re: No spark ??
« Reply #6 on: 12 May 2011, 09:34 »
Got power to the coil. Changed the dizzy cap leads are 6 months old
Yeah I dd flood the engine but I did dry everything off. Just wired I got spark on ignition but not when I turn it over? Thanks anyway
