Author Topic: Engine bay and coil packs  (Read 1382 times)
Offline 1 gti
« on: 11 May 2011, 18:43 »
This might be obvious but want to check. Are the coil packs the 4 black rubber things below the engine cover? As soon as you take the cover they're right on top of the block? Mine are being done tomorrow and want to make sure they're being changed not trying to get away with it. Going to Mark each one
Offline T_J_G
Re: Engine bay and coil packs
« Reply #1 on: 11 May 2011, 18:50 »
Yes they are your coil packs what engine code is it?
Takes 20 seconds to do each one.
Offline 1 gti
« Reply #2 on: 11 May 2011, 18:55 »
Thanks. It's going in for the recall because my car has recently been misfiring and running lean. I've got VAG-com myself and done a scan and it said cylinder 4 misfired and random/multiple misfires. Hoping they'll do the 4 not just 1. Engine code is AUQ and it's an Anni
Offline opel
« Reply #3 on: 11 May 2011, 22:13 »
it only certain code ones that get changed. think it that last letter on the coil and if it a certain letter they change them. so u will have to wait and see it not all coils being replaced
Offline 1 gti
« Reply #4 on: 11 May 2011, 22:22 »
It has been recalled it's just never been done. Printed off a copy of the faults from VAG-com incase they try to say it's something else
Offline opel
« Reply #5 on: 11 May 2011, 22:24 »
they recalled them all the just wont to check the code on the coil pack. if u got the lucky part number u get free replacement if not i think they will charge u for the coil if u wont them done
Offline 1 gti
« Reply #6 on: 11 May 2011, 22:36 »
From my understanding on the phone they're going to change them free. I shall have another chat with them when I drop it off and make sure. Let you know how I get off tomorrow  :wink:
« Reply #7 on: 11 May 2011, 23:56 »
Does this recall apply to all AUQ's or only certain years.
 :smiley:
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #8 on: 12 May 2011, 09:04 »
Its a bit of a mix i believe.  I tried it with my AUM but they said the coils are fine, i know they're not as VAGCOM says one of the is misfiring.
However Opel got all of his changed on his AUM, so you've just gotta be lucky!
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline StusDUB
« Reply #9 on: 12 May 2011, 09:17 »
Got all 4 of mine done and mines a AUM  :grin:
