Author Topic: running issues  (Read 607 times)
Offline jimmy1888
running issues
« on: 11 May 2011, 17:03 »
Hi all,
my car (1.8t AGU) has been running ruff for a while, the car stands for a fortnight each month unused as im at work and the last twice when i returned to the car it would not start, jumped the car both times and it started fine. I cleaned the throttle body a couple of months ago and the car idles fine for a few seconds then the revs jump upto 1200rpm.  I though i was starting to have coilpack issues as it seemed to be misfireing at idle so i got it scanned today and the only fault code it showed was "Low Voltage at terminal 30" the guy then load tested the battery and advised to replace.  fitted a new battery fitted and changed the spark plugs while i was at it,lol.
should this cure the ruff running?
cheers :wink:
Offline andc1
Re: running issues
« Reply #1 on: 11 May 2011, 18:17 »
low voltage code is battery low voltage ie been disconnected or run flat, idle could be maf sensor, air leak, boost leak etc etc etc
if it sits for a while it might be worth a blast out for a while(obviously no more than 70mph!! :laugh:)
