Author Topic: leaky sunroof  (Read 2270 times)
Offline hockeylad72
leaky sunroof
« on: 28 March 2005, 00:07 »
HELP AGAIN!
as the subject says I have now got a leaking sunroof just before i start ripping the whole lot out anything common for this type of problem, eg seal or blocked drain hose. It leaks at the rear edge just above drivers seat.
Thought dubs were less troublesome, still great fun tho
cheers
Davie
Offline Mr Blue
Re: leaky sunroof
« Reply #1 on: 28 March 2005, 00:25 »
Sounds like you sunroof seal has gone.
Open the sunroof. unscrew all the screws you can see. remove the sunroof reflector and the guides.
now close the sunroof half way. Dont tear the interior pannel!. The pannel comes out but pulling on the front edges of it. 'Ya get me'  :cool:
anyway now you hold the pannel in place and wind the sunroof open fully and this should leave you with the pannel. Now slide the pannel up and out.
Should be more clear on how to take the sunroof off after that. ive never done it myself
hope that helps :laugh:
Offline piggy
  • What you lookin' at sonny?
Re: leaky sunroof
« Reply #2 on: 28 March 2005, 00:33 »
Try winding it back and running some water into the drain holes? and poking some thin cable down them if it doesn't drain straight away. :smiley:
Sometimes just moving the sunroof and applying a small smear of Vaseline around the seal will help if it's a small leak.
I keep a tub next to my bed for such occasions :embarassed:
« Last Edit: 28 March 2005, 00:53 by piggy »
Offline PeeWee
  • GOLF GTi 1.8 8V
Re: leaky sunroof
« Reply #3 on: 28 March 2005, 00:38 »
you keep a small tube by your bed for occasion's.. so are you a leaky person  :smiley: :smiley: :smiley: :evil:
  89 SILVER GTi 8v  <br />
Offline piggy
Re: leaky sunroof
« Reply #4 on: 28 March 2005, 00:53 »
When you get to my age, everything leaks. :laugh:
Offline PeeWee
  • GOLF GTi 1.8 8V
Re: leaky sunroof
« Reply #5 on: 28 March 2005, 00:58 »
well i'm older than you and i'm as toight as a toiger ha ha ha ha  :smiley: :laugh:
Offline piggy
Re: leaky sunroof
« Reply #6 on: 28 March 2005, 00:59 »
You've got the opposite problem to me then?
Anally retentive!  :laugh: :laugh: :wink:
Offline hockeylad72
Re: leaky sunroof
« Reply #7 on: 28 March 2005, 10:49 »
think some one is straying from the question  :grin:
Offline piggy
Re: leaky sunroof
« Reply #8 on: 28 March 2005, 21:25 »
You checked the drain holes? :smiley:
Offline hockeylad72
Re: leaky sunroof
« Reply #9 on: 28 March 2005, 22:14 »
unable to check nothing still raining! don't have a garage which is a right pain, will have to wait till rain stops could be a while a I live in Scotland 0.
sorry I'm that use to seeing Scotland with a zero after it :laugh:
