Author Topic: Mk3 Gti 2.0 8v - Starting Problems  (Read 1442 times)
Offline Jb-Dub
« on: 10 May 2011, 18:44 »
Hi,
I have a 2.0 8v gti and its been sitting for a few months, and its having starting problems.
i have changed the battery, coil pack, leads, dizzy cap, rotor arm, and plugs, also had the aftermarket imobiliser removed and chucked some new fuel in with some additives to make it that little bit more combustable.
It will turn over fine and then start, but soon the needle on the rev counter gets up to around 1000 revs it dies, ive tried it many times and the same thing every time.
Just wondering if any one has had this problem or know what the problem is??
Would be a massive help
Jb
Offline neil1780
Re: Mk3 Gti 2.0 8v - Starting Problems
« Reply #1 on: 10 May 2011, 18:57 »
Crank sensor mate.
V6 4MOTION
Offline Jb-Dub
« Reply #2 on: 10 May 2011, 21:19 »
Cheers mate I've got a few more things I've Been told to try
And ill this too
Jb
Offline mk2_abf
« Reply #3 on: 10 May 2011, 22:43 »
Ignition timing is your best bet
Offline Jb-Dub
« Reply #4 on: 11 May 2011, 00:10 »
How can i check timing ?
you have to have it running to do that right ?
Jb
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 11 May 2011, 00:12 »
Was it running fine before you parked it up?
Offline nightroamer
  • Mk3 16v
« Reply #6 on: 11 May 2011, 07:42 »
Is it dying after only a few seconds? Crank sensor fault it often wouldn't start at all.
« Reply #7 on: 11 May 2011, 09:20 »
Not true, quite often with crank sensor failures the vehicle will run fine until it's warmed up and then will often cut out when reducing speed when driven eg. approaching a junction etc.
Offline Shady Pioneer
  • graphic designer.
« Reply #8 on: 11 May 2011, 11:09 »
It can also just happen whenever.  :grin: My Anni had a crank sensor failure. Admittedly when the engine was warm it was worse, but it can cut out when doing 60mph (like I was). Mine wouldn't start at all sometimes even when cold.
Offline nightroamer
  • Mk3 16v
« Reply #9 on: 11 May 2011, 12:30 »
Fair one, I guess there is always gonna be a difference between a total failure and a partial failure also, like breaking down coils where they warm up etc.
