Author Topic: flashing coolant/temp light  (Read 1103 times)
Offline Dan_GTi8v
« on: 10 May 2011, 18:07 »
I have an aum in my mk3 and the dash coolant light is flashing. Not sure what the coresponding light is in the mk4 but im guessing its the same :P what could be the causes? It has coolant in it and the wiring all looks ok. It flashes as soon as I start up so dont think its the engine temp as it doesnt have a chance to heat up. any ideas?
Offline richw911
Re: flashing coolant/temp light
« Reply #1 on: 10 May 2011, 19:47 »
Dirty contacts in the coolant bottle which makes the ECU think there is no coolant in the bottle.
Clean them or replace the bottle for £15 for a brand new one  :wink:
Offline Dave_IOW
« Reply #2 on: 10 May 2011, 19:49 »
i had this problem and cleaned the sensor, 12 months on, still fine  :smiley:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Dan_GTi8v
« Reply #3 on: 13 May 2011, 18:10 »
sensor is clean, it stopped flashing for a bit when I took it for a test drive, but came on again a few mins later
Does the routing of the radiator pipes make a difference? I wasnt sure which way to put them on the mk3 rad so I have the top right hose going to the top of the rad and bottom left hose going to the bottom of the rad. Its an aum and a 8v GTi rad, is that the right routing and would it make a difference?
