Author Topic: Bearing Noise From Timing Belt End Of Engine  (Read 6540 times)
Offline richandhazel
« on: 10 May 2011, 16:20 »
Just thought I would share this experience with my fellow Mk1 owners:-
All last year, since putting the cab back on the road, and this year I have been suffering with a loud noisy bearing noise from the timing belt area of the engine. I had convinced myself that the new tensioner that I had fitted was at fault so last week I fitted a replacement tensioner and belt.........only to find the noise still there :angry:
This afternoon, as the weather is nice, I took the car for a spin and the noise seemed louder than ever so I tried to troubleshoot it.
I removed the aux drive belt to take the water pump and alternator out of the equation and ran the engine briefly - noise still evident.
I removed the top timing belt cover and ran the engine briefly - noise still evident
At my wits end I tried slackening the timing belt tension slightly - noise disappeared :shocked:
So on both timing belt and tensioner changes I had overtightened the tensioner!
Sounds great now :cool:
Offline Guy
Re: Bearing Noise From Timing Belt End Of Engine
« Reply #1 on: 10 May 2011, 23:21 »
oopsy! at least you have it sorted now and can operate more peacefully  :cool:
Offline JamesW
« Reply #2 on: 11 May 2011, 12:49 »
The fun of hunting down funny car noises  :grin:
Offline SoundillusioN
« Reply #3 on: 13 May 2011, 16:11 »
Good tip... I didn't document it but I had similar when I changed my cambelt recently... Being paranoid that the belt was too loose, I did the same as you and overtightened it and along came the noise.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 13 May 2011, 16:17 »
From what Ive read (but not personally experienced) is that it's quite common for new cambelts and tensioners to give out a certain amount of noise when new due to the fact they haven't bedded in yet and will quieten with use.
Was it a manual or automatic tensioner that you fitted?
« Reply #5 on: 13 May 2011, 16:25 »
Manual which is the norm in a mk1...  it was literally a couple of mm adjustment in it to shut it up for me.
« Reply #6 on: 13 May 2011, 20:27 »
Likewise, just a minor tweak slackening the tensioner fixed it.
MOT time already......booked in tomorrow just after the Mk4.
Offline Guy
« Reply #7 on: 16 May 2011, 10:14 »
how did you get on?
« Reply #8 on: 16 May 2011, 10:42 »
how did you get on?
Has it been a year for the cabby already!?  and yeah, how did you get on with it?
« Reply #9 on: 16 May 2011, 13:17 »
Both cars passed, Mk1 had no advisories, mk4 had one :smiley:
That year did go very quickly didn't it :shocked:
