Author Topic: a host of questiosn 1.8 8v related  (Read 1629 times)
Offline wurth
« on: 09 May 2011, 21:04 »
hello. Currently in the process of swapping engines in my ryder.
The engine going in is a 1.8 driver.
The questions  have are :
1) I currently have a elec fuel pump and reg in my car, is it worth holding on to and removing mech fuel pump and blocking off with a plate ?
2) are the crankshaft pulleys and alternator the same on the 1.3 mk2 engine to the 1.8 mk2 engine ?
3) Should there be a gasket between the M/S and the servo on a corrado/gti setup (not taking about the o-ring)
4) As it is a corrado M/S and servo im using, do peeps just block the pipe out of the resivour (clutch pipe??) ?
5) Im trying to identify the cam I have in there, and can only come up with a few numbers : L wwo 026 1e  one side, and L (vw badge) 3E the other ??
Im sure there will be more questiosn soon.
Thanks
Offline Diamond Hell
  • Opinions я Us
Re: a host of questiosn 1.8 8v related
« Reply #1 on: 09 May 2011, 21:49 »
Not really. Nothing wrong with the 'big block' mechanical pump.
Don't think so - just fit those on the 1.8
Yes, it seals for the servo vacuum.
Get a Golf2 GTI one - no pipe to block.  Doesn't your existing one fit?  They just pull off.
No idea, but you want a PB head to replace the GU (or whatever it is) head - bigger valves, so more flow.
Offline mk2bal
« Reply #2 on: 09 May 2011, 22:02 »
Keep the fuel pump and reg- even if you don't use it straight away you may want to if the mech 1 packs up/ engine change later on etc etc
Offline wurth
« Reply #3 on: 10 May 2011, 22:28 »
diamond hell, so theres more than just the rubber o-ring on the m/s servo ?
And i am aware I want a pb head, but thats not what I have... Im after identifiying a camshaft, not what head to buy.
So the 1.8 crankshaft pulley is model specific ?
