Author Topic: VCDS coding for RNS 510-Help wanted? :laugh:  (Read 7749 times)
Offline WHITEY20
  • Love my new Golf
« on: 09 May 2011, 20:17 »
Please can someone help?
I've fitted my RNS 510-B
Had it coded on VAGCOM, cam working, MFSW working and MFD but no voice on NAV
Installed firmware 2680 but then in German and reset settings in VCDS
Installed v7 maps
Tried recoding with VAGCOM, rear cam now working, but no audio at all.
I have Dynaudio installed but what options do I choose?
Speakers front & rear or Sound system?
Dynaudio or Dynaudio BAP ?
Mic inactive? ( I havent retro-fitted a mic)
Any Ideas anyone????  :huh:
DSG, 18", P/A+cam, Winter/P, Lux/P, Dynaudio, FTI, Bi-Xenons
Offline richyrb
Re: VCDS coding for RNS 510-Help wanted? :laugh:
« Reply #1 on: 09 May 2011, 20:38 »
i found little difference choosing front and rear or just front with a none dyna.. but you will probably have to choose front and rear with the dyna
choose dynaaudio setting tho.
but when you do see how it sounds.. if it doesn't sound 'right' then do it again with the other one..
with the mic you generally shouldn't select anything you don't have installed on the car as it might throw up error's.
in regards to the no sound.. what setting has it put it too? no sound system installed?
Offline WHITEY20
  • Love my new Golf
« Reply #2 on: 09 May 2011, 20:49 »
We've tried "front & rear" and also "Sound System" but in another byte there's 2 different options for Dyno.
I can't remember whether or not "mic inactive" was ticked.
We've had error codes for CAN CONTROLLER and MULTI-DISC(which Ive since unticked the MULT-DISC/I-POD box)
Offline mike.
« Reply #3 on: 09 May 2011, 21:01 »
I have the coding for a RCD510 with Dynaudio fitted. Coding: 0101004001
I know the channels would be different, but if you could cross reference them with the RNS510 it might help.
I was trying to have a look on google to see if I could find them but had no luck.
Another option is to drop an email to RossTech with an autoscan of the car, they have always been very helpful to me.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline WHITEY20
  • Love my new Golf
« Reply #4 on: 09 May 2011, 21:10 »
Cheers Mike,
but whats an autoscan?
Offline mike.
« Reply #5 on: 09 May 2011, 21:16 »
It's an option in VCDS that scans the entire car with details of each modules coding.
It explains it a bit better HERE
It creates a txt file which can then be attached to the email.
Offline Buck
  • Das Auto
« Reply #6 on: 09 May 2011, 21:58 »
Slightly off topic but...
I have my RNS510* C fitted which darren kindly coded for me.
I can't get voice control to work though (I installed the bluetooth phone kit myself at the weekend :) whcih works fine)
Any ideas?
Thanks
Adrian
Offline WHITEY20
  • Love my new Golf
« Reply #7 on: 09 May 2011, 22:05 »
Nice one Mike, I've printed it of and i'll take it with me to get a txt file.
Offline branchespark
« Reply #8 on: 09 May 2011, 22:10 »
@Buck,
Do you know if Darren also supplied the microphone cable from the Bluetooth to the RNS? I believe (and I am yet to do it and also have no voice control) that you need to pass the microphone through the RNS and then back to the Bluetooth. (I have the new iPhone capable Bluetooth kit that can also do audio to the RNS*C - is that the same as yours?)
You can see more information @ http://www.my-gti.com/1234/volkswagen-rns-510-microphone-connection-for-voice-control, but it covers a number of options. A few repair connectors from VW, 5m of shielded MIC or speaker cable and job done!
I'm sending you the VCDS cable tomorrow, so you should be able to check if that's the issue when you have it. Within VCDS, you should see some errors in the Navigation module saying that the MIC is open circuit (or similar.)
Sam
« Last Edit: 09 May 2011, 22:12 by branchespark »
Mk6 GTD 5dr | Manual | Deep Pearl Black | 18" Vancouvers | Leather | Xenons | RNS510* + VW Premium Bluetooth (iPhone4) + Dynaudio | Smoked LED tails | Cruise
Offline Buck
  • Das Auto
« Reply #9 on: 09 May 2011, 22:41 »
@Buck,
Sam
Hi Sam
Thanks for the reply - I bought one of the BT boxes that's compatible wiht my iPhone4 so yes, will probably be the saem or v similar.
I bought the wiring loom set from eBay Poland(!) (Car Systems) - There were 3 connectors built into the wiring loom - two females and one male - I fastened one set together then the male from the microphone to the other female if that makes sense - I wonder if I have got them the wrong way around - I though it was OK as I could use the phone !?
I look at the above on my-gti.com and also when I get the VCDS cable I can delve a bit deeper - thanks for all your help - appreciated
