Author Topic: Polished alloy refurb.Updated with problem.  (Read 4003 times)
Offline Big Tone
« on: 09 May 2011, 08:13 »
I have seen plenty of info on the net about refurbing alloy wheels where filler is used then painted/coated over once smooth.
However, my wheels have a polished "face" and I would like to remove the scratches and scuffs from this face, I think that I have two options;
1. File/emery out the scratches then polish up.
or
2. Fill with something suitable (Any reccommendations), sand down then polish up.
Dont want to attack the wheels and end up making a mess, but I am unsure as which (If any) filler is suitable to use.
Any help/experiances are appreciated.
« Last Edit: 16 May 2011, 11:12 by Big Tone »
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
nige_s
Re: Polished alloy refurb.
« Reply #1 on: 09 May 2011, 10:30 »
If you want to keep them bare polished then you need to manually remove the scratches, file the worst out then wet and dry increasing the grade, then use a metal polish with plenty of elbow grease.  Thing is if its very deep you'll need to remove alot of material to get the surface something like, problem with that is that you'll be removing material! so depending on the wheel design that could be some critical strength, whilst also losing the surface detail/shape.  If it's that bad you might be best having it done professionally who can then properly weld/fill the bad out.
I'd only use filler on fine cosmetic scratches which are then going to be painted.
Offline Shady Pioneer
  • graphic designer.
« Reply #2 on: 09 May 2011, 11:26 »
Just out of curiosity (sorry to hijack thread) but is it easy to refurb polished alloys back to a paint finish?
nige_s
« Reply #3 on: 09 May 2011, 11:34 »
Just key, fill/smooth out any scuffs then use an etch primer before you paint or get them powder coated, etc.
  • graphic designer.
« Reply #4 on: 09 May 2011, 11:37 »
Cool! I'm thinking of something special for my TT wheels, polshed wheels are a pain in the ass to maintain.  :grin:
nige_s
« Reply #5 on: 09 May 2011, 11:40 »
Floral vinyl wrap?
  • graphic designer.
« Reply #6 on: 09 May 2011, 12:22 »
Too late for that, water and the winter storage has already taken it's toll on them. :cry:
nige_s
« Reply #7 on: 09 May 2011, 12:34 »
I had this guy polish/refurb my Porsche Fuch rims, 2 sets, for £300!  That was a while ago and I cut a bit of deal with him.
http://www.maverickwheels.co.uk/
Very good and reasonable cost, though he isn't that local to you.
Offline Big Tone
Re: Polished alloy refurb.Updated with problem.
« Reply #8 on: 16 May 2011, 11:18 »
Tried to do my wheels at the weekend and realised that I will never get the polished face the same as what it was originally as it is coated, what do I do?
1. Sand and paint the whole wheel?
2. Sand and POLISH the entire face of each wheel? (My preferance)
3. Leave it?
4. Any other suggestions?
Before;
After
Yes, I know it needs lowering.....If only money grew on trees!
« Last Edit: 16 May 2011, 11:24 by Big Tone »
Offline murraymint
« Reply #9 on: 17 May 2011, 13:14 »
that needs lowering...... lol
yh if you sanded the whole face and each time you did it use finer and finer paper then entually you will get the polished look back, gunna take some time tho,
you could use sanding wheels and a drill to speed up time
josh
