I just bought this off Ebay for £40.00
Hardly used, belonged to the girls Grandmother, still has the original bill of sale with it, and is immaculate!!
Fuji finepix S602 Zoom
3.1-megapixel Super CCD interpolates to produce 2,832 x 2,128-pixel images.
Improved CCD system with Pixel Coupling allows 1,600 ISO at 1.0-megapixel setting with low noise.
Faster than average shutter response and shot to shot cycle times.
6x telescoping zoom lens (35-210mm equivalent).
Pixel Mixing Technology for high-quality, VGA digital resolution movies at a full 30 frames/second!
Im selling this camera on behalf of my gran who has owned the camera from new. The camera has hardly been used and is still in excellent clean condition.
Comes complete with
Padded carry bag
Optex wrist carry strap
Instructions
128mb memory card
16mb memory card
USB lead
Did I get a bargain, or was I ripped off?
This is what I have been using...
Colour RED
Dimensions Height=6.1cm Depth=2.3cm Width=9.6cm
Manufacturer Warranty 1 Years Cover included
5 X optical zoom Makes the subject appear closer, whilst retaining high image quality.
2.7 inches Screen size For composition and colour viewing of your shots.
LCD screen type This allows you to control the main functions of the camera without having to use any buttons.
Digital Image stabilisation This 28mm lens allows you to capture a larger viewing area a nd allows for more expansive photography
24.5 mm wide-angle lens For wider field of vision
VGA Movie mode allows you to record video footage with audio
Intelligent scene recognition The camera detects the environment and selects the best setting to capture the optimal image
Face detection technology This technology lets the camera automatically optimize focusing, flash control and white balance for capturing faces clearly and brightly.
smile detection technology Smile detection will prevent a photograph from being taken until everyone in it is smiling
blink detection technology Blink detection prevents a photograph being taken if anyone in it is blinking
CCD inches Image sensor This is very important in determining the quality of the photograph. The larger the sensor, the better.
Rechargeable lithium-ion Battery type Rechargeable, compact sized battery with no memory effect so they can be recharged at any time. Charger also supplied.
80 1600 ISO rating This number indicate the cameras sensitivity to light. The higher the sensitivity the less light is needed to make an exposure.
260 Maximum shots per charge The average number of pictures which can be taken with the cameras battery life.
USB cable included in the box Faster downloading when connected to a USB port on your PC.
AV out connection Audio Visual connection.
PC software included Download your images to a PC to edit, e-mail or print.
Automatic ISO Automatically adjusts the ISO for each shot.
Macro mode Allows filming close up without loss of focus.
Red-eye reduction Reduces the possibility of red eyes by sending out a flash or beam of light to reduce the pupil size before the main flash fires.
50 mm minimum focusing distance For close-up photography. In some instances, a Macro mode may need to be switched on to achieve this distance.
Self-timer Allows you to get into your own photos.
Auto power-off Switches the camera off if not in use.
Battery level display Shows when the battery is due to be recharged or replaced.
Hand strap included Hand strap included
14.2 megapixels .
Continuous shooting Your camera takes several photographs in sequence allowing you to capture a much wider scene
Hand shake alert Your camera will warn you when your hand is moving too much to take a clear picture
Slideshow playback .
SD storage media indicates which type of memory card is required
Toby
