Author Topic: Damn Damn Damn  (Read 2936 times)
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Damn Damn Damn
« Reply #10 on: 08 May 2011, 12:16 »
Having said that the 037-906-022 N model I have matches the Bosch Part Number, but not the VW one.... :huh:
For More Info Click To See;
Offline tomp
Re: Damn Damn Damn
« Reply #11 on: 08 May 2011, 12:25 »
So what we need to know is how interchangable they are, anyone?
Offline tomp
Re: Damn Damn Damn
« Reply #12 on: 08 May 2011, 15:07 »
Managed to borrow an ECU, same as the one photographed above from someone locally (I have to replace it)
Fuel pump primes and then stops which is now right but the idle control valve is running constantly, is that normal?
Car still won't start, got the plugs out at the moment as its damp in there...
Don't seem to have a very good spark, anyone got any suggestions?
Offline tech1889
  • Mk2 GTI FTW !!
Re: Damn Damn Damn
« Reply #13 on: 08 May 2011, 16:08 »
you've f**ked the sparky plugs ?? or they need a clean from being dowsed in petrol ??
Offline tomp
Re: Damn Damn Damn
« Reply #14 on: 08 May 2011, 16:14 »
Yeah you probably right, will put a blow torch on them and see if that improves things once I have let everything dry out a bit...
Offline emery1990
Re: Damn Damn Damn
« Reply #15 on: 08 May 2011, 18:00 »
Pretty sure the isv can stick sometimes, take it apart and cleaning it out may make it go off when it's suppose to.
Offline tomp
Re: Damn Damn Damn
« Reply #16 on: 08 May 2011, 20:51 »
Finally got the car started, took all the plugs out and put an airline down the holes,  heated the plugs up - still no joy  :angry:
Wasn't getting a spark so started checking other stuff, turns out that the ignition module on the ecu bracket on the ecu I borrowed was no good, put the original one back on and it started straight away.
Just need to do an oil and filter change as the oil smells a bit of petrol after the original ecu failed and completely flooded the engine.
Offline benji mk2
  • Soon be christmas!
Re: Damn Damn Damn
« Reply #17 on: 09 May 2011, 11:32 »
I had this happen on a breakdown I attended once, pulled out a plug and the injector had stuck open,  lots of fuel, hot engine bay, flames, oh f**k. Thank you Mr fire extinguisher!!!!!
