Author Topic: RH zw1's with LCR brembo's?  (Read 1946 times)
Offline Mark_eire
« on: 07 May 2011, 20:24 »
Ok, so I ditched the idea of the zender wheels.
I'm now looking to get a set of RH zw1 wheels, I'm just going to go for 17's though as the Irish roads aren't best suited to 18's on a mk4!
I'm running a set of LCR brembo's with 323mm discs,
My question is, will a set of 8.5x17 zw1's with 225/45/17 tyres fit over the brakes and work without problem's?
They are ET33 when using 20mm 5x112-5x100 adapters.
I've looked at the wheel offset calculator and it tell's me that this setup will have 14mm less inner clearance, but have 12mm extra outer position, which I like!
Can anyone tell me if this will work, as I'm not really sure how to figure it out myself!!
Thanks!
2004 Audi A4 Avant 1.9tdi Sport, S4 Avus wheels
2001 VW Golf Gti, green, revo, S3 leather Recaro's, US front bumper, LCR Brembo's, Audi A8 18'' Flat fives
Re: RH zw1's with LCR brembo's?
« Reply #1 on: 07 May 2011, 22:29 »
That is going to be tight on 17", 312mm is tight enough under 17"  :undecided:
Offline Mark_eire
« Reply #2 on: 07 May 2011, 22:35 »
I'm running 17's at the moment, but the s3 wheels have loads of room under them!
Offline Mark_eire
« Reply #3 on: 11 May 2011, 19:56 »
anyone?  :smiley:
Offline ashw831
« Reply #4 on: 11 May 2011, 20:23 »
s3's dont run brembos do they - i know they are 312mm's but are the brembo calipers not thicker?
Offline Mark_eire
« Reply #5 on: 11 May 2011, 21:05 »
I've got a mk4 gti with LCR brembo's an s3 wheels!  :grin:
Offline Grand Master Patch
« Reply #6 on: 11 May 2011, 21:24 »
No chance :sad:
