Author Topic: Not a good start!!!! Enginemanagement????  (Read 2255 times)
Offline rob249
« on: 07 May 2011, 16:01 »
Ok after buying the golf mk4 2.0 gti (8v), 2000 reg at 10am, a warning light has already appeared on the dash. According to the manual i thinks its the exhaust emmision warning lam, excepct without the lightening bolt through it, but to me it looks like ENGINE MANAGEMENT light on any other vehichle that ive owned.
why would this be? it could be anything couldnt it???
Could someone try and clear this for me please (its due a service aswell and car notifies me every time i start it up)
1. Is the the water supposed to be orange?? i think its the antifreeze colour maybe. Its in a big round ball type thing on the left side of engine bay
2. when starting up the starting motor makes a loud squeal sometimes, why woudl this be?
Im clueless on golfs to be honest. DOnt wanna spend a fortune but know i need:
1.cambelt
2.water pump
3.fan belt
4.oil
5.filter
6.plugs
« Last Edit: 07 May 2011, 16:11 by rob249 »
Offline matping
  • MK1 20vT MK5 GTI T
Re: Not a good start!!!! Enginemanagement????
« Reply #1 on: 08 May 2011, 22:27 »
as for the engine management light  bud you need to get a code reader on it  to see what fault codes it shows this will pin point the fault
the round ball = the expansion bottle  for the coolant and sounds to me that it allready has summer coolant in ! you can check this with a cheap antifreeze tester ! or dip your finger in see if it tastes sweet !  :wink:
the sqeal is the starter moter sticking on due to dirt and old grease  ! there is a guide on here for stripping it down to clean  i started  it ages ago !
http://www.golfgtiforum.co.uk/index.php?topic=139484.msg1265517#msg1265517
heres the guide to cleaning it
http://www.montreal-vdubbing.com/forum/viewtopic.php?t=43
as for the parts you need try      - http://www.thetradepartsspecialists.co.uk/
« Last Edit: 08 May 2011, 22:35 by matping »
Offline rob249
« Reply #2 on: 08 May 2011, 22:35 »
as for the engine management light  but you need to get a code reader on it  to see what fault codes it shows this will pin point the fault
the sqeal is the starter moter sticking on due to dirt and old grease  ! there is a guide on here for stripping it down to clean  i read it ages ago !
The fault code showed P0001 Fuel Volume Regulator Control Circuit/Open, dont know what that means :cry:
Ok thats a good sign then i will taste it tomorrow haha
Ok thanks for the starting motor tip ill check something out as asoon as i can
And thanks for the parts site seems its 5mins away from where i live
Offline matping
« Last Edit: 08 May 2011, 22:41 by matping »
Offline rob249
« Reply #4 on: 08 May 2011, 22:42 »
have you checked here for the fault code?
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
Ye p0001 is not there, its on obdII scanner i think, but cant find what exactly ''P0001 Fuel Volume Regulator Control Circuit/Open'' means for anything, some websites state code is a fault or fake
Offline matping
« Reply #5 on: 08 May 2011, 22:45 »
where you from pal and what did you scan it with ? vag-com ??
Offline rob249
« Reply #6 on: 08 May 2011, 22:49 »
Im from Swansea in Wales, and scanned it with one of the scanners in the link below
http://www.oursbiz.com/Company/210220/U480_Can_Obdii_Eobdii_Memo_Scanner.aspx
Showed up as 1 fault, and then gave the code 01, when i checked the manual, the only 01 code was p0001
Offline matping
« Reply #7 on: 08 May 2011, 22:52 »
bit far away from me  you could do with a good scan with vag-com
this is for vag
http://www.amazon.co.uk/Scanner-Reader-SKODA-diagnostic-Fault/dp/B001KSZQNM
« Last Edit: 08 May 2011, 22:55 by matping »
Offline rob249
« Reply #8 on: 08 May 2011, 22:54 »
ok ill see about anything i can google locally then
cheers though
Offline matping
« Reply #9 on: 08 May 2011, 22:56 »
ok yes keep me posted ! ive also changed the last message i sent to show you a vag scan tool
