Cosmetic and bodywork matters
Headlining Glue
Topic: Headlining Glue (Read 1818 times)
Kiz
Just got here
Headlining Glue
07 May 2011, 14:05 »
Anyone know what glue i should use to repair my sagging headlining.
JC
10k hero
Back in the North.
Re: Headlining Glue
automotive and heat resistant.
Kiz
Just got here
Re: Headlining Glue
07 May 2011, 14:10 »
Cheers Chuff
vw-8v
Here all the time
Re: Headlining Glue
09 May 2011, 00:29 »
i have same prob after using a heavy duty spray one i have been advised and have bought a product called trim fix adheisive spray off ebay. also evo stick
and
http://www.screwfix.com/p/evo-stik-528-industrial-contact-adhesive-2-5ltr/42076
the link i have used already after the first stuff i used didn't work when bonding to the c pillars and this stuff is strong i aint ever getting the material bk off lol it expensive but really good thinking of tring it on roof linner aswell but it aint the easiest thing to apply as it does dry pretty quick if trying to cover such a large surface in my case my headliner has a patter so if i need to move the material i would have no luck if it an all one colour then it may work but mind it a brush on so need to spread evenly and avoid material soaking and glue coming through.
good luck
tshirt2k
Been there...Done that...
Re: Headlining Glue
20 May 2011, 22:00 »
Best glue is wickes contact adhesive. Not spray on but very sticky. You have to let i go touch dry before sticking together though.
Mk3 ABF 16V
T
Megasquirt V3
Headlining Glue
