Author Topic: door card removal  (Read 4232 times)
Offline DC90
door card removal
« on: 07 May 2011, 13:04 »
I've trying to change my electric wing mirror on the passenger side. I've removed the top plastic which covers the window switch and door handle and removed the window switch. I removed 2 medium sized brass screws underneath (the only too i can find) how do i get the rest of the door card off? or at least enough to unplug the wing mirror.
I've looked for guides on removing door mirror and they simply tell me to "remove door card" and the door card removal guides aren't very much help either/
Can someone direct me to a detailed guide on getting to it? Apologies if this has been covered, I did try the search function but only found brief descriptions. I also found a link on here which was supposed to be a good one but the page fails to open.
« Last Edit: 07 May 2011, 13:08 by DC90 »
2008 Skoda VRS TDi
1997 Mk3 Golf VRS
Offline iyrix
Re: door card removal
« Reply #1 on: 07 May 2011, 13:21 »
There is about 3 or 4 bolts, rest is just clips that pop off.
this should help...
You dont need to remove speaker grill.  Unscrew the locking pin.
Golf GTI 16v
Offline DC90
« Reply #2 on: 07 May 2011, 13:57 »
thanks for that mate. Finally done it.
2008 Skoda VRS TDi
1997 Mk3 Golf VRS
