Author Topic: DELOCK A MK4 GOLF REAR DOOR  (Read 2204 times)
Offline rabbit1973
« on: 04 May 2011, 23:46 »
HI THERE . CAN ANYONE TELL ME HOW TO DE HANDLE AND DELOCK THE REAR DOOR ON MK4 GOLF AND STILL OPEN THE DOOR?    THANKS
Re: DELOCK A MK4 GOLF REAR DOOR
« Reply #1 on: 04 May 2011, 23:47 »
Well it will still open from inside or you need a popper kit
Offline Jack3559
« Reply #2 on: 05 May 2011, 10:24 »
IF YOU SEARCH EBAY IT SHOULD COME UP WITH A KIT.
Offline houston
« Reply #3 on: 05 May 2011, 10:30 »
WHYS EVERYONE SHOUTING!!!
assume you mean the boot as the rear doors dont have locks, the lock itself can be removed then glue a metal disc in there and fill it to cover the hole left, if you mean the complete handle removed then youll need a solenoid release fitted and the hole will have to have a plate welded over it and filled.
or you could graft a mk5 handle in???
Offline Jack3559
« Reply #4 on: 05 May 2011, 20:42 »
HIS CAPS WERE ATTACKING MY MASCULINITY SO I NEEDED TO RETALIATE.
Offline Trispage
« Reply #5 on: 05 May 2011, 21:15 »
Is the mk5 handle a direct fit for the mk4 or is there work involved ?
Offline Rhyso
« Reply #6 on: 05 May 2011, 21:23 »
Lots of work involved - cutting your boot for starters
Looks the dogs danglies when done though  :smug:
