Author Topic: GTI 16v Anniversary on PH/Autotrader  (Read 11090 times)
Offline Jack4688
Re: GTI 16v Anniversary on PH/Autotrader
« Reply #90 on: 07 May 2011, 16:25 »
Right, had a couple round to look at the Polo this afternoon, they seemed interested  :smiley:
If they go for it I'll have a look at this little beauty: http://www.gumtree.com/p/cars-vans-motorbikes/golf-gti-3-door-16-valve/78269546
I know its been nearly halfway to the moon but it's a 16v in black and nearby :afro:
Other than rust anything particular to mk3 GTIs worth looking out for?
One more thing I thought of in terms of a comparison between 8v and 16v models is the engine braking effect - I usually slow down as much as possible just using the gears (when it's safe to do so obviously, I'm not driving round hoping to get rear ended in some insurance scam  :laugh:) but found that there is barely any effect in my Polo until you're doing very low speeds. Anyone else have a similarly uncomfortable (for any passengers who regret accepting a lift  :grin:) driving style? I'm guessing that the 2.0 engine will have more weight and inertia and maybe there is little effect in the Polo because it is only a 1.4.... but can anyone comment on any difference between the 8v and 16v?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #91 on: 07 May 2011, 16:43 »
My current 16v drops it's revs slower than my last couple of 8v's did. It took a little bit of getting used to at first but im used to it now...well until i eventually get round to sticking a lightened and balanced flywheel in it.
Offline Jack4688
« Reply #92 on: 07 May 2011, 16:48 »
When I drop into 3rd from 4th or 2nd from 3rd absolutely bugger all happens, where as the Ibiza used to slow down really well with any gear change and I was always too scared of doing some expensive damage in the S2  :cry: ....until wrote it off!
I suppose I'll have to get used to a lot things anyway - power, torque, biting point, clutch weight etc etc
Offline Shady Pioneer
  • graphic designer.
« Reply #93 on: 07 May 2011, 17:58 »
At least you're joining the right MK.  :cool:
Offline Jack4688
« Reply #94 on: 07 May 2011, 22:08 »
At least? Why, what have I done wrong now?  :embarassed:
Offline shepgti
« Reply #95 on: 07 May 2011, 22:16 »
If you have a choice then get a 16v however i will say its not worth buying a lemon 16v if a decent 8v is availiable(probly for less too), at the end of the day neither are quick cars so dont expect them to be.
« Reply #96 on: 07 May 2011, 22:19 »
Nearly a grand for that with 150k on it is having a  :laugh:
Offline Jack4688
« Reply #97 on: 07 May 2011, 22:25 »
Well aren't most mk3s on the internet similar?
Offline Jack4688
« Reply #98 on: 07 May 2011, 22:30 »
And if anyone's having a laugh it's this chump: http://www.pistonheads.com/sales/2784686.htm
Look out for the 'subtle touches' as he calls them, I bet even the most eagle-eyed of you out there won't be able to pick up on what he means by that :grin:
« Reply #99 on: 07 May 2011, 22:34 »
It pays to shop around, a grand for that is not cheap £750 is nearer the mark.
