Author Topic: My 02a Gearbox won`t go into reverse. Help.  (Read 1089 times)
Offline Nige
« on: 02 May 2011, 08:24 »
Bit of a strange one. Using the car last week I I tried to get reverse, but it wouldn `t go in.
Initially, I thought it was the selector cables, but I opened the bonnet, manually pushed the selector weight down and moved it into reverse. Starting the car and lifting the clutch and it still goes forwards  :sad: I`ve had a passenger go through the gears and I am 100% I`m trying to move it into reverse, rather than 1st.
When pressing the selector down, it doesn`t go all the way down, I`m sure it did before.
The gear selection feels like it is reluctantly going into reverse, but it isn`t actually engaging the gear.
I removed the shifter tower and checked the oil level, it needed a little bit adding, but not much. The shifter tower looks fine, nothing bent / broken.
Any suggestions ? I`m guessing its something inside the gearbox, but just thought I`d ask.
Offline danny_p
Re: My 02a Gearbox won`t go into reverse. Help.
« Reply #1 on: 02 May 2011, 12:32 »
never met that problem on an 02A before.  be very suprised if it was a gear problem, may be worth swaping the selector tower over for another if you have one hanging about to see if it makes any differance
all the VW's have gone bar 1.
Offline Nige
« Reply #2 on: 02 May 2011, 22:01 »
I don`t have another. I`ll go to the local scrappies and see if I can get one from them.
Does seem very odd  :sad:
