Author Topic: how low should i go?  (Read 3158 times)
Offline dubdob
« on: 30 April 2011, 22:01 »
i really want my more door mk3 gti to sit low, but it is also my family car. can anyone recomend how low i should go? i was thinking 60mm.
Re: how low should i go?
« Reply #1 on: 30 April 2011, 22:21 »
Yes around 60mm really :cool:
Offline dubdob
« Reply #2 on: 30 April 2011, 22:43 »
is it ok to drop it with springs on standard shocks? if not ill save up for some spax coilies cos my mate sh*@ged a set of jom in about a week and i need my car every day.
Offline Damon1991
« Reply #3 on: 30 April 2011, 23:09 »
Im not certain on this but I believe you shouldn't lower a car more than 40mm on standard shocks, as it can cause the shocks to give up, but im sure someone on here will either confirm or correct me :D
Offline dom
  • Back in a Mk4
« Reply #4 on: 30 April 2011, 23:41 »
The person above is right, even a 40mm drop is pushing it really. Standard shocks will fail very quickly after fitting lowering springs, really you need shortened shocks to go with them.
Spax coilovers will do the job very nicely, they won't be cheap mind!
Offline fecked_tt
  • 4wdftfw
« Reply #5 on: 30 April 2011, 23:42 »
hot tuning ebay cheapies ftw
a4 2.8 30v v6 quattro gets me vag
« Reply #6 on: 01 May 2011, 00:04 »
As above really, or fit a cheap set of coilovers and set as you feel the need.
Offline dubdob
« Reply #7 on: 01 May 2011, 01:02 »
venom do 30% uprated shocks 30/40 pound a corner has anyone used these? im really suspisious of cheap coilovers. i can get spax for £260. what should i do. (need a confused smiley).
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 01 May 2011, 02:28 »
VERY LOW!!!  :wink:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline fecked_tt
  • 4wdftfw
« Reply #9 on: 01 May 2011, 02:54 »
check my 5 series its on its arse with another inch on the threads if you wanted...
depends if you want lowness or ride quality to be honest.
