Author Topic: Swapping ignition barrel from '94 Valver to '96 Anni? Igniton switch replacement  (Read 4839 times)
Offline Shady Pioneer
  • graphic designer.
Thanks Neil. :) It was easier than I thought it would be.
With regards to the ring, as I've only one key, what would be the process of get a spare key done as I've only one at the moment.
Offline Screech16v
  • MK3 20vt AGU
Should be a sticker in your service book with a code on it,just go to vw and quote this :smiley:
  • graphic designer.
I will have look. Thanks screech.
VW BUSH
Quoted me £120 :shocked: go to one of those key cutting chains should cost about £35 :wink:
Just thinking the same, a key cutting place will be a lot cheaper. :smiley:
Offline Screech16v
  • MK3 20vt AGU
What about the chip in the key for the imobliser?
They can code them I believe.
Offline trog_nfs
They most certainly can. Just need your old key to cut and code a spare
Offline Screech16v
  • MK3 20vt AGU
I never knew that , cool  :smiley:
Offline leegt5
Glad you got it sorted !!
