Author Topic: Swapping ignition barrel from '94 Valver to '96 Anni? Igniton switch replacement  (Read 4826 times)
Offline Shady Pioneer
  • graphic designer.
Re: Swapping ignition barrel from '94 Valver to '96 Anni?
« Reply #10 on: 30 April 2011, 23:01 »
You reckon? It would save a lot of hassle if it was just the switch, so may try getting them swapped over tomorrow then. Will take my old one off the Valver and replace the Anni's one (if I can). What joint under the pedals are you referring to may I ask?
Offline leegt5
« Reply #11 on: 30 April 2011, 23:06 »
Yeah the puller method is to remove the splined collar compressing the spring above the upper column bearing inside the barrel housing as in the top picture.
Its a fookin nightmare as I did it and you will more than likely destroy the splined collar trying to chisel it off as I couldn't get a puller to pull it off so needed to replace the splined collar when putting things back together.
Best way I would say to do it is see below to lift out column.
Remove upper steering column stroud (2 screws) and unplug all electrical adaptors around column and disconnect the steering wheel airbag connector and do not change its position in relation to the steering wheel.
Remove shear bolt off casing
Remove plastic cover above pedals.
Unbolt lower steering column from UJ (1 Bolt and nut and needs to be completely removed the bolt from column.
Now with some gentle tapping of the underside of the steering wheel the steering column should lift completely out with indicator arms still attached. You should now be able to access the ignition switch to remove it and change for a new one.
Putting back is as reverse, lower column back down tube and attach to UJ in correct position as the bolt will only go back through in one position as the lower column has a d shape cut in it.....
« Last Edit: 30 April 2011, 23:24 by leegt5 »
  • graphic designer.
« Reply #12 on: 30 April 2011, 23:15 »
Thanks Lee, that's basically the same as what I found here:
http://forums.vwvortex.com/showthread.php?2532481
Going to give it a go on the Valver, if I can do it then I'll do the Anni, if not, then...will have to try again at a later date.  :grin:
Offline neil1780
« Reply #13 on: 30 April 2011, 23:19 »
If you look under the clutch pedal theres a plastic cover, under this is a joint for the steering disconnect the bolt on the column side.
looks like this and the arrow points to where you need to put the chisel in to loosen it then the column will pull out.
theres no need to mark anything for reasembly as it will only go in one way, theres a rescess on the column for the bolt in the joint youll see what i mean and you dont need to take the steering wheel off.
V6 4MOTION
Offline neil1780
« Reply #14 on: 30 April 2011, 23:22 »
this didnt work for me mate hense the chisel but it might for you every cars different.
« Last Edit: 30 April 2011, 23:24 by neil1780 »
V6 4MOTION
  • graphic designer.
« Reply #15 on: 30 April 2011, 23:24 »
Seems to be the easier option, basically the same as what was said in the linked thread by Lee, and the VW Vortex one I found. I'll give this ago tomorrow. Would be nice to get the ignition area sorted. :cool:
Thanks for the help lads, will report back with whatever happens.
« Reply #16 on: 01 May 2011, 00:11 »
Or a flat balde screwdriver will do the same trick, on mine it did not need anything after I removed the bolt.
Offline Screech16v
  • MK3 20vt AGU
« Reply #17 on: 01 May 2011, 11:28 »
I also ued that thread on vortex,was such an easy way to do it ,took the colunm compleatly out ,took it in the house ,changed the switch sittin on me sofa inbetween havin me dinner ,misses givin me strange looks lol,was done in no time  :smiley:
  • graphic designer.
Taken this from my Dub Rides thread, hopefully it'll help someone that has a similar issue. :afro:
So today I changed the ignition switch, all by myself.  :grin:
After input from another thread by members saying it could be a switch issue, I took it upon myself to try and correct the problem. Said problem was that when turning the key I had to lift it up slightly to get the engine to start. I had taken the ignition switch from my old valver when that was being broken so I used this as a replacement.
Here is the U-Joint, known for being a complete b!tch to get the nut and bolt to part from the main joint. This is what took up most of my time and it wasn't comfortable lying on my back trying to do so either:
Once this bolt was out, there is a allen bolt holding the column in place that's directly to the left of the ignition barrel location (other side of the steering wheel). I undid this and thankfully the steering rack just came straight out without much problem. DIYs I've read have suggested it might not always be that easy, sometimes involved having to chisel or knock the U-Joint with a flat-headed screwdriver, but this wasn't necessary in my case. Also note before pulling out the rack you need to disconnect all wires leading to the steering wheel.
I'm not 100% sure what this bit if but it was around my ignition barrel:
Steering rack out with everything still attached:
Old switch to the left, valver's one to the right. You can tell the different and why I had an issue:
The infamous small screw that holds the switch in, quite fiddly to get to but I found a cheap small Halfrauds screwdriver did the trick, other suggest a jeweler's screwdriver as they are very thin:
All I had to do was put it back together. The tricky part was the U-Joint and putting the steering rack back in, I found the part that connects to the U-Joint (in the spring area) was a pain to locate the right position, but I got there in the end, put the bolt back through and made sure everything was back the way it was meant to be. Took me about an hour.
So my problem regarding the switch is fine, but my barrel needs replacing at some point as the engine will still run if the key is taken out.  :rolleyes:
Offline neil1780
Well done mate glad it's sorted :afro:
That ring is the immobiliser ring that detects the key.
V6 4MOTION
