Author Topic: 1.8T Clutch snap when pressing? 2 bits of plasitic and a slice of metal?  (Read 1429 times)
Offline bigstring
it's the Mrs A3 1.8T, but all the same, Problems again...
Never known a car have so many problems!
Was going from 4th to 5th aroun4 40mph last night on the bye-pass and there was a loud clunk, the clutch pedal hit the deck and I pulled over, I found 2 bits of plasitic and a slice of metal in the foot well.............
1x white plasic clip snapped
1x black plasic cover? I thing
1x 1.5" bit of metal?
Clutch is fine in this car and just covered 100 miles in it about an hour before, not the master cylinder or anything like that, is this a common problem, can anyone shed any light, parts needed or a how to?
I can see a metal rod and the pedal, I take it this was attached :rolleyes:
Cheers people!
jamie16v
common problem on the mk4 platform, quite cheap and easy enough to fix. search the mk4 section for more answers,.
Offline bigstring
Cool beans people.... thank you......
Also on that note, I snapped a little pin that was attached to a pinkish box? about 3" long and 2" wide (the box) the pin about 1cm'ish..
