Author Topic: Problem with cooling fan - can anyone help??  (Read 2825 times)
Offline Miss Piggy
« on: 08 September 2003, 14:54 »
Hope someone can help......
I have a k reg 1993 1.4 Golf CL (I think that's a Mark 3 :-[ - not the best at car stuff!!!).
I've got a problem with the fan - basically the fuse keeps blowing, so I think I've got a problem with the wiring or the fan motor...... I can't afford to spend too much on it, so any help/advice would be gratefully recieved..... what should I look for, what might I need to replace, how much would I expect it to cost if I do take it to a garage?
Also, anyone know any good garages in the Newcastle area??
Thanks!
golfvr6
Re:Problem with cooling fan - can anyone help??
« Reply #1 on: 08 September 2003, 15:03 »
hello again,
I think if the wiring loom isn't damaged then the motor itself is at fault. About ?150-?200 to get done at a garage for the motor itself.
Corin
Offline Miss Piggy
« Reply #2 on: 08 September 2003, 15:09 »
Sounds expensive..... :(
Thanks for your help though.
Rae
Offline richandhazel
« Reply #3 on: 11 September 2003, 11:15 »
Might be worth a quick look to make sure that the fan blades are rotating freely. I had a similar problem on my cabrio when I first started it up after 5 years in a garage. Turned out to be a dent in the fan/radiator cowling was preventing the fan from turning :-\
golfvr6
« Reply #4 on: 11 September 2003, 16:01 »
Yep, got to worth a look. Unplug the fan then spin it by hand, see if it is noisy or gets stuck on anything.
