Author Topic: Bottom radiator hose O-ring  (Read 717 times)
Offline Planty
« on: 28 April 2011, 14:26 »
Does anyone know what size the O-ring is that goes between the right angle joint on the bottom radiator hose? Also I might get a new clip as well if anyone can tell me what part that is? Did the thermometer recently, and must have disturbed it.
Its a 1.8 CL AAM
Cheers in advance.
Offline javalin
Re: Bottom radiator hose O-ring
« Reply #1 on: 28 April 2011, 20:39 »
you mean the thermostat recently, so the t-stat o-ring?  GSF or dealers I'd guess.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #2 on: 28 April 2011, 21:33 »
Dealers is the best bet, will not be expensive.
