Author Topic: Interior lighting issues  (Read 3140 times)
Offline neil1780
Re: Interior lighting issues
« Reply #10 on: 28 April 2011, 20:00 »
Both are easy replaced but the headlight switch is a strange looking bulb has a big long plastic stem never seen one before.
V6 4MOTION
Offline les.tansey
  • VW Golf R32 MK5 & Mercedes-Benz E320 CDI Estate
« Reply #11 on: 29 April 2011, 04:51 »
I was thinking a fuse aswell, but in saying that i replaced all of the fuses and my heater control lights still don't work :sad:
(As above) Golf MK3 & genuine BBS RX 16"wheels, now for sale separately - Just ask for details - Thanks, Les
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #12 on: 29 April 2011, 08:53 »
The tiny singular bulb commonly fails in the heater control panel. It costs pennies and about 15 mins to replace.
Offline nikkiy9
« Reply #13 on: 29 April 2011, 19:20 »
yep, mine failed too, had to take all the dash surround out, thank god i had to fid my cd player at the same time
Offline dom
  • Back in a Mk4
« Reply #14 on: 29 April 2011, 19:26 »
I thought you could just pop the front of the heater control panel off? :undecided:
Offline Shady Pioneer
  • graphic designer.
« Reply #15 on: 29 April 2011, 20:26 »
Me too! Is this not the case?
Offline dom
  • Back in a Mk4
« Reply #16 on: 29 April 2011, 20:37 »
I'm pretty sure it is! If I remember correctly it's a bit fiddly but it's definitely doable, there are some little spring loaded rod things which are a bit of a b!tch to sort as well I think :wink:
Offline neil1780
« Reply #17 on: 29 April 2011, 22:36 »
pop the the front panel off and theres 4 screws to undo then pull out the control panel and you will see the bulb should take no longer than 10-15mins.
V6 4MOTION
« Reply #18 on: 30 April 2011, 00:02 »
Exactly that, the fascia simply pops off then remove the 4 screws on each corner of the heater dial unit and pull it forward, you'll then see a white plastic cowl on the rear of the unit which pulls off off. Beneath this is the the bulb holder which will have a green filter around it. remove this and withdraw the bulb.
Offline LowlifeDubber
« Reply #19 on: 30 April 2011, 09:51 »
Or a quick tip is pull the knob off the centre dial.Get a small piece of rubber vacuum hose and push it onto the bulb.Once it is located in the tip of the pipe,give it a pull and out it comes.
For refitting just put it very lightly in the end of the pipe and push back in.
Jobs a gudn :)
