Author Topic: Rear Shocker pops into boot  (Read 1365 times)
Offline The Hoax
« on: 23 March 2005, 22:42 »
I have a 1990 Oak Green 16v and there has been an annoying squeak coming from the rear. I thought it was the parcel shelve brackets, but all was revealed when the top of the shocker popped straight through into the cabin.
There is a washer of about an inch and a half diameter at the top of the rear strut on the under side. If you loosen the nuts and rubber bush in the boot you will see it. Mine had completeky stress fractured . I checked the other one and it was going the same way. Worth checking if you have a real irritating noise from the rear
Anyone else had this problem?
Offline Dizzie
  • Make friends with your fast
Re: Rear Shocker pops into boot
« Reply #1 on: 23 March 2005, 22:51 »
sounds like someone has bodged that in the past to avoid paying out to fix it properly :sad:
Offline Mr Blue
« Reply #2 on: 23 March 2005, 23:23 »
yes :grin:
Offline Gambit
« Reply #3 on: 24 March 2005, 09:28 »
with my old 16v i rebult the whole rear assembly from the bumpstop upwards. all parts from VAG cost £32 all in
