Author Topic: Sparks from Gearbox Earth Strap  (Read 1195 times)
Offline mbGti
« on: 26 April 2011, 20:03 »
Have got an 8v mk3 gti. The car started having problems starting in the last 2 days. The starter motor would turn slowly and eventually get the car going. Its not turning at all now and sparks are visible from the gearbox earth strap.
I have tightened it up and even tried running a jump lead from the battery negative to the engine block, but even that sparks when cranking and the starter doesnt turn.
Is there any other places I should be looking. Im also slightly worried as there appears to have been some melting on the wires to the coil.
Offline dashey
Re: Sparks from Gearbox Earth Strap
« Reply #1 on: 01 May 2011, 03:26 »
I think your gona need a new starter motor as its not taking the current so arcing out
