Author Topic: noisey fan belt!!  (Read 1200 times)
Offline kniterider
  • had most, sold most and often buy more!
noisey fan belt!!
« on: 26 April 2011, 19:38 »
as above really,
only on start up though, one quick blip of the throttle to 4000 rpm and its gone, may rear its head if i put light on with full beam and fogs and load the alternator up a bit, belt is plently tight enough... its on a 91 mk2 16v, any one know the right fan belt size as ill prob try a new one or one thats a bit wider as the pulleys look a fair bit shiney/ worn. unless its easier to convert to a multi v elt arrange ment if i can grab some pulliers off something else?
Offline Sam
  • Sam I am
Re: noisey fan belt!!
« Reply #1 on: 26 April 2011, 20:05 »
Just replace the belt, easiest option. Also give the v's in the pullys a rub down with some wire wool and you should be laughing.
Offline kniterider
« Reply #2 on: 26 April 2011, 20:37 »
gonna pick one up tomorrow and ill rough the pullies up a bit and see if it makes some difference, its had a new belt not long back but squeals like a pig when you start it whether hot or cold till you blip it, bet the neighbours loved it a 4:45 this morning...
lol
Offline kniterider
« Reply #3 on: 27 April 2011, 15:52 »
pullies roughed up in the v's with my diamond file and a new gates belt fitted and nice peaceful starting! , wondered what noises start next!! going back to k-jet after having alot newer stuff for long you become a bit paranoid of noises , and lumpy splutters / misfires!! but thats the joys of it all haha
Offline Sam
  • Sam I am
« Reply #4 on: 27 April 2011, 16:15 »
Job done!
