Author Topic: Nice simple question for someone :)  (Read 1514 times)
Offline Barnzyuk
« on: 26 April 2011, 14:52 »
Hi All,
I am curently going through the process of converting my mk2 to run an 02a box. One little thing i'm not sure about is where does the mechanism that causes the gearstick to bounce up to stop you engaging reverse go, presumably there is a spring on the shaft where there is a small notch cut out?
I have a corrado cable shifter, but it doesn't spring up like you would expect.  :huh:
The Steak 5.0
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
Re: Nice simple question for someone :)
« Reply #1 on: 26 April 2011, 16:12 »
Is it not on the bottom of the gearstick mate???
Offline Barnzyuk
« Reply #2 on: 26 April 2011, 20:28 »
Not as far as I am aware, but I'm not sure. I thought it was something on the shaft as I appear to be missing a few bits from the shaft (highlighted components in diagram below I don't have) when compared to the ETKA Diagram so assumed it was one of these bits I needed.
The Steak 5.0
Offline apie2004
« Reply #3 on: 26 April 2011, 20:41 »
You are gay
The game
lololololololol
Offline Barnzyuk
« Reply #4 on: 26 April 2011, 23:30 »
You are gay
The game
lololololololol
thank you for you input James  :huh:
The Steak 5.0
« Reply #5 on: 27 April 2011, 10:40 »
that pic is from the tower in the engien bay, the reverse lockout mech is all on the stick itself. there should be a spring on the shaft somewhere
Offline Barnzyuk
« Reply #6 on: 27 April 2011, 13:27 »
Ah that makes sense, I misinterpreted the diagram. I don't have a spring on my shaft, so will try and source one. thanks for your help!  :smiley:
The Steak 5.0
