Author Topic: Same brake bulb keeps blowing  (Read 2418 times)
Offline AdrianChelt
« on: 26 April 2011, 11:15 »
I have a 2005 GTI, for some reason I keep getting the same brake light bulb blowing. It is the nearside one.
This happens every 3 months or so. I have tried different makes of bulb (including a halfords shock resistant  :rolleyes:), this makes no difference.
Looking at the light unit I can see nothing obvious that causes this...
Anyone any ideas?
Thanks in advance
Adrian
Mk5 Manual 5-Door Diamond Black, CD Autochanger - wishes he had realised value of highline
Offline Jimp
Re: Same brake bulb keeps blowing
« Reply #1 on: 26 April 2011, 11:56 »
Only a minor thing but when installing the new bulb do you hold it with a clean cloth or tissue? Sometimes the natural oil/grease on your finger tips can really reduce bulb life, which is a pain if you do a lot of early morning or night driving.
Not low enough mk5
Not on the road enough mk3
Offline Gene Hunt.
« Reply #2 on: 26 April 2011, 14:02 »
Could be a faulty earth connection.
Candy White ED35.
Offline Egbutt Wash
« Reply #3 on: 26 April 2011, 14:55 »
My thoughts were an intermittent connection.  Have someone drive behind you when lightly touching the brake.
Currently digging a bunker.
Offline AdrianChelt
« Reply #4 on: 28 April 2011, 11:33 »
Thanks for the suggestions.
I tried watching the brake light whilst my wife was driving... no flicker, it looked fine
I could not see a individual earth for the brake light, it is a multi-plug for all the boot based lights. I guess they would all have a problem in that case.
At least replacing the brake light bulb is easy!
Hot tip for anyone trying it... snip the thread across the split in the bootside cover - it makes it so much easier to get at the bolts & plug
