Author Topic: Supercharger!  (Read 1863 times)
Offline Gash
Supercharger!
« on: 25 April 2011, 23:22 »
Well might be supercharing the ABF watching a charger on ebay... £100 no bids! :D
all i need then is the ecu and il be good to go.. well and a bracket etc but easy done
is £300 good for a mega squirt?
Offline benvictors
  • bgk Tuning - coming soon!!!
Re: Supercharger!
« Reply #1 on: 26 April 2011, 09:34 »
Depends on the megasquirt, you need to make sure you get megasquirt with the Map sensor on it (MPX4250 i think) to handle the boost. Also its not normally just the case of plugging Megasquirt in and off you go, its quite in depth setting it all up properly.
You will also need a head gasket spacer or double stack yr head gaskets to lower compression, all related pipework, pulleys and belts, intercooler, bigger injectors, possibly a bigger fuel pump and will need to modify yr sump for an oil feed for the charger.
Make sure you take plenty of pics an post yr progress  :wink:
Offline tweed
Re: Supercharger!
« Reply #2 on: 26 April 2011, 12:29 »
thinking of charging my 8v and make it look stock as possible. G60 look.
Offline Gash
Re: Supercharger!
« Reply #3 on: 26 April 2011, 13:44 »
yea i know about the other bits. basically following a thread on e38 for a charged abf.
brackets can make up etc and the other bits i can get easy just thinking about the price as i can get a 20v T fitted for about £600ish and then if i wanted can easily tune that more. where as if i have a charged abf (although AMA|ING) can i tune it as much for the same amount... plus will cost me about £500-600 to do it too
Offline Jack3559
Re: Supercharger!
« Reply #4 on: 26 April 2011, 13:47 »
WIN
Offline justalex81
Re: Supercharger!
« Reply #5 on: 26 April 2011, 14:06 »
who's fitting a 20vt for £600?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Supercharger!
« Reply #6 on: 26 April 2011, 14:52 »
I was wondering that myself?
Offline Gash
Re: Supercharger!
« Reply #7 on: 27 April 2011, 11:13 »
me and my mate
hes fitted his mk2 with a 20v so asked him to do it :D
Re: Supercharger!
« Reply #8 on: 27 April 2011, 13:28 »
Could / will work out cheaper to fit a 1.8t  :undecided:
Offline Gash
Re: Supercharger!
« Reply #9 on: 27 April 2011, 14:41 »
thats what i was thinking. although he did just tell me the turbo has a slight play in the shaft and i need a loom.
there is a agu on here for 250 with everything i need so might take that up :P
