Author Topic: MK3 Golf Anniversary (Operation OEM+) - Vandalism - Thanks Yeovil  (Read 336976 times)
Offline gtiballs61
  • Wanted-nearside wing in lp3g(flash red)
Re: Flash Red MK3 Golf 20th Anniversary - Photo whore
« Reply #580 on: 07 October 2011, 21:59 »
lovely shot :cool:
Offline Shady Pioneer
  • graphic designer.
Offline GrandMstRamRod
« Reply #582 on: 10 October 2011, 00:26 »
took you 59 pages but blacker then black arch trims nice pic anyway dude ;)
  • graphic designer.
« Reply #583 on: 13 October 2011, 17:58 »
Managed to sort the 1200rpm problem. The sensor plugged into the throttle body was loose, also had the throttle body error codes reset and now it's running the way it should.  :cool:
« Reply #584 on: 23 October 2011, 13:55 »
how about lets not and say we did!
  • graphic designer.
Re: Flash Red MK3 Golf 20th Anniversary - Almost sold her!
« Reply #585 on: 09 December 2011, 23:41 »
I almost sold Ruby the weekend before last. I went to Manchester to see vdubninja about his car for a swap with mine (vdub, thanks for the coffees and good chat :afro:), but on the return home I decided I really didn't want to get rid of mine after all.
Don't know what it is but I just want to stick with the old gal. That being said, bloody thing has it's issues but I will be getting most of them sorted in the next few weeks. First being the MAF needing replacing, I changed a front oil breather pipe yesterday (£66 from the bloody stealers!). The old one was completely fecked and both ends had been damaged, upon taking out one end the end just came off and stayed where it was connected.  :grin: That's how bad it was.
Anyway, plans are to get a few things sorted and then start saving. Might end up having the first 20VT MK3 Anniversary.  :lipsrsealed:
Offline Ninja
  • 19 smiles per gallon
« Reply #586 on: 11 December 2011, 09:30 »
See mate! You were well eager to do the swap, but I said it's best we both think about it. Ruby is a stunner, and I wanted to:
A) Be sure I wanted her
and
B) Make sure you were making the right decision.
And isn't it a good job you waited!
Glad you made the right decision.
I'm in two minds now after meeting ruby... Do I go all out and get another MK3 (Might go for a pre done 20VT) or do I just fix Scarlet's gremlins, then slam her and map her.
Loving the wheels on Ruby btw mate.
And finally, don't listen to these haters your seats are FECKING AWESOME! And KEEP the red belts!!! :lipsrsealed:
Did you eat your freddo btw?  :laugh:
  • graphic designer.
« Reply #587 on: 30 December 2011, 15:02 »
New Falkens tires on the way for the front, also some new discs and pads as I noticed the steering and brake pedal vibrating under pressure. Hopefully it's those that sort that problem.
Also, not sure why but second gear when cold doesn't lock into gear a smoothly as all the other gears, it doesn't crunch as such, but doesn't have a sense of 'oh, I felt that go in'. What could be the problem there?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Flash Red MK3 Golf 20th Anniversary - Part buying
« Reply #588 on: 30 December 2011, 15:38 »
Second gear issues are common as muck on these, fit a new linkage bush kit and treat the box to some fresh oil and I reckon it'll be sweet. My last 8v was exactly the same when I bought it.
  • graphic designer.
« Reply #589 on: 30 December 2011, 15:52 »
Cheers thai. Just read rubjonnys guide for the mk2 which I am to believe are the same, so if I buy a repair kit (about £18 on eBay) I'll have to get this sorted as it is annoying. Should tighten up all the other gears too then I take it?
