Author Topic: MK3 Golf Anniversary (Operation OEM+) - Vandalism - Thanks Yeovil  (Read 337421 times)
Offline Shady Pioneer
  • graphic designer.
Re: Flash Red MK3 Golf 20th Anniversary - New additions
« Reply #510 on: 13 September 2011, 20:25 »
 :lipsrsealed: :grin:
  • graphic designer.
« Reply #511 on: 26 September 2011, 00:32 »
GrandMstRamRod, guess what! I cleaned the car, and blacked the trim!!!  :grin: Proof for you tomorrow.
Have a new interior too, I imagine many won't think it goes but meh, I really like it. It's different.  :grin:
  • graphic designer.
« Reply #512 on: 26 September 2011, 00:45 »
Also, found this tube today, not connected to anything:
Also I think I may have found out my issue of cutting out under braking. Just to the left of the tube I'm asking about, you can see another with a little part coming out, with another rubber tube in it along with a screw. This is my temporary fix until I get a proper seal as this little section had a rubber nipple that was damaged and pulling in air. After doing this bodge job I feel it is better because the car isn't dropping under 900rpm at all now. Fingers cross this was the problem.
Back to the main tube, it leads to this unit behind the coolant tank:
Offline Adam
« Reply #513 on: 26 September 2011, 01:42 »
 :wink:
Down Hill From Here.
« Reply #514 on: 26 September 2011, 08:03 »
So you have got Adam;s old interior, should be interesting to see.  :undecided:
Offline dan_apps
  • too low for british roads!
« Reply #515 on: 26 September 2011, 15:30 »
looks like your talking about the vac pipes here shody, and yes it will cut out should you have leaks or the pipes are perished, change them out bud! :smiley:
  • graphic designer.
Here you got then, pictures!
And how look when out of the car:
Clean car!
And many thanks to Godzilla, what a beast! Quite literally, sent me some lovely centre caps to finish off the RX2s:
Now for the bad stuff. Sadly, my car is running at 1200K rpm constantly, I have looked online and most likely due to the throttle body clean so have to disconnect the battery for a few hours to allow it to reset.
Offline Bellend
Sure you haven't left any vaccum pipes loose? Mine was idling at 1200 when there while I was waiting for a vaccum pipe. Once on it was fine.
New vaccum pipe from the servo to the manifold from VW if needed is about £45.
Where all my moneys went.
Offline GrandMstRamRod
« Reply #518 on: 26 September 2011, 19:50 »
good lad :) did you like that message via xbox
Offline Dan34
  • VTEC Powerzzzz
That interior looks pretty cool shady! i like it.
