Author Topic: MK3 Golf Anniversary (Operation OEM+) - Vandalism - Thanks Yeovil  (Read 336975 times)
Offline Shady Pioneer
  • graphic designer.
Re: Flash Red MK3 Golf 20th Anniversary
« Reply #180 on: 04 May 2011, 09:11 »
haha
give it a beasting with the new bit on, sure it be reet :D
Not giving it a beasting until I at least have got the gear linkage kit, but I can't really afford to get that right now. Got some play in the gear shifting so want that sorted for 'positive gear change'.  :grin:
Still need to get my camber and tracking done too as currently my front wheels have got 'stance'.
Offline Jack3559
« Reply #181 on: 04 May 2011, 09:23 »
Mine had front stance a little while ago... had to buy a new pair of front tyres every month.
To remedy it until I could get it tracked I just loosened the hub/strut bolts and reset the camber which did a pretty good job of saving rubber.
  • graphic designer.
« Reply #182 on: 04 May 2011, 09:29 »
Think I need to get them done asap, I have been running a few days like this, and have brand new Falkens on the front. Don't want to feck them up.
Offline Jack3559
« Reply #183 on: 04 May 2011, 09:37 »
Yeah, whack the wheels off, loosen those bolts and tug on the hub at least that way you'll get slightly more even wear...
Offline jeynesey
  • Non VW but still VAG
« Reply #184 on: 04 May 2011, 13:13 »
How are you finding the Falkens bud?
  • graphic designer.
« Reply #185 on: 04 May 2011, 13:35 »
I really like them. I haven't driven with them properly at the moment due to camber and tracking but when they were on the valver they were superb.
Offline jeynesey
« Reply #186 on: 04 May 2011, 16:40 »
Weird isnt it? I HATED the falkens I had  :undecided:
Hope car is sorted soon :afro:
  • graphic designer.
« Reply #187 on: 06 May 2011, 11:02 »
Gear selection is a hell of a lot better since replacing the bracket. Just need to replace the ball mechanism to stop so much slack whilst changing gear.
Offline robz
« Reply #188 on: 06 May 2011, 13:21 »
magic!!
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #189 on: 07 May 2011, 10:33 »
Have not read it all mate, but mine deleloped a lot of slack too, it was a simple bush thing in the engine bay area that had wron out, on the arm for the geasr shif mech.. i dunno what its called, anyhow Ben victors made me a new one and that solved it. took 5 mins to fit..
not sure if your prob is same but just throwing it to you
Not no ordinary GTI....
www.mixcloud.com/kells/
